Torque converter sugestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 07:53 AM
I changed cams in my 402 last weekend and now I need a converter so it idles in Gear better. I changed to one I had laying around and it's still to tight. I'm open to sugestions so here's the specs. 79 Malibu with no weight reduction around 3600, th350, 3.73 gear with 27" tire. Motor is 408" big block, 8.5 compresion, weiand stealth with 750 vacuum secondary holley, small tube headers, and a comp xe268 cam. The cam specs are 224/230 at .050, .515/.520 lift and 110* seperation. They list the range as 1600-5800. Also I don't want to go high dollar on this as the th350 is planned to be changed to an overdrive in the future and this is a street car that will hardly ever see the track.
Old 03-24-2010, 01:40 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
Where is your initial timing?? For that cam in a big block, you should not really need a loose converter. I'd say you'll need at least 12į of initial timing with that cam and motor combo.
Old 03-24-2010, 01:58 PM
X's 2 . In a big block you should not even need a stall .
Old 03-24-2010, 02:35 PM
The timing is 16* intial 36* total plus vacuum advance at manifold vacuum. It needs a converter.
Old 03-24-2010, 02:52 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Guys, it's still only a 402 cid engine, BBC or not...
Old 03-24-2010, 02:58 PM
Sometimes I think I need to just leave the bb part out and just say it's a 408" chevy.
Old 03-24-2010, 04:18 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
I have this one behind my 383 w/ a th350.
http://www.summitracing.com/parts/BMM-20404/
Seems like a nice piece so far. 2,400 stall. I imagine it would stall a little less behind your 408 but would give you enough slip at idle.
Old 03-24-2010, 04:37 PM
Rickracer's Avatar
Even in a healthy 355, an XE 268 could get by without a converter. Probably could use a little looser converter though. I take it this motor doesn't have all that much compression? I'd try a little more initial timing, especially since that's free ...
Old 03-24-2010, 05:25 PM
Yep it's only got about 8.5 unfortunately. The car is driveable with the converter it has now but it pulls on it hard in gear.
Old 03-25-2010, 07:58 AM
Oh really , Your telling there is no differance between and big block head design and a small block?
Old 03-25-2010, 08:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I'm telling you that the engine is a 402/408. That it is a BBC and not a SBC accounts for a couple percent difference in the peak power between the two, were they built to the same cam specs and CR. But that's not the whole story.
The matter at hand is the torque converter, and whether or not he needs one w/a higher than stock stall speed (he does) and how much stall speed he needs (enough to put the engine at or very near the torque peak when hit hard from a dead stop).
Actually, given the much larger ports/valves/header diameter of the BBC heads (non PP oval port's- forget about rectangle ports, they'd need a TON of stall speed) on a 400 cid-sized BBC, the 402 could need MORE stall speed than a 400 SBC w/smaller ports.
BTW- in the quote of yours:
In a big block you should not even need a stall.
you seem to think that a "stall" is what you go and buy. This would be incorrect- "stall" refers to an RPM range where the TC is applying the most force to push the vehicle forward. If you walk up to a salesman in the speed shop and ask for a B&M stall- don't be surprised if he laughs.
Old 03-26-2010, 07:37 AM
BTW- in the quote of yours: you seem to think that a "stall" is what you go and buy. This would be incorrect- "stall" refers to an RPM range where the TC is applying the most force to push the vehicle forward. If you walk up to a salesman in the speed shop and ask for a B&M stall- don't be surprised if he laughs.
I ran a very similar cam in my 396 chevelle with stock converter for 5 years . No problems . If he has a lighter car than I could see it needing a stall .
Old 03-26-2010, 07:59 AM
There's a good chance your 396 had more compression than my 402 has. I am considering a 10" converter from redneck. It's only $170 shipped.
Old 03-28-2010, 07:49 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I've never dealt w/Redneck. Just please- do not ask them for a 10" "stall". LOL
I see you do use the correct term, so I'm preaching to the choir- but anyway... A 10" might be a bit much, actually. You should be more than able to get by w/a 11" TC. I'd prolly just give them a call and talk it over w/them to get a recommendation.
Old 03-28-2010, 05:23 PM
I emailed them Friday with all my info on the car. They emaailed me back and said there cheap 10" should work just fine. It's only around a 2200-2600 stall I beileve. I've been doing alot of reading and it seems that a tight 10" converter is more effcient than a 12" or 11" in the same stall range. So it might be a direction I'll go. I drove the car this weekend to a car show and it does seem better now with the old summit converter I put in there, but I think it would be better with a little looser comverter.
700R4 Torque Converter Flexplate Question fosterdl Transmission - Rearend 8 03-23-2008 01:03 PM
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 06:53 PM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 01:46 PM
Torque Converter Failure - TH350 blown81 Transmission - Rearend 1 10-16-2005 12:41 PM
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 09:52 PM
