Torque converter won't fully seat in transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2007, 10:18 AM
When I tried to install the converter, it thumped 3 times like it should, though it didn't feel like it went in as far as it needed to. I tried putting the trans up to the engine and the converter was wedged against the flywheel while I still had about 3/8" gap between the engine and bellhousing.
I know the stator and input shaft inside the transmission is engaging and I also know it's engaging the pump, it just doesn't seem to be going in all the way. When I constantly turn it while pushing in for a few minutes, it becomes a royal pain in the *** to remove, even though it doesn't seem to be sliding farther on the shafts.
Is it normal to have the clearances this tight? Edge Racing rebuilt the converter and I'm pretty sure they replaced all the internals.
I'll include a link to some pictures of the front of the transmission, you can see the shiny marks on the stator where it stops You can also see where it's engaging the input drum. I know it's engaging the pump because after I pull it off after spinning it, the 2 tangs for the pump gear are in a different location. Should I just keep pulling it back and pushing it in over and over until it finally slides all the way in or is there something wrong with the converter? I've been at it for a few hours now and have made no progress at all, all I need is another 3/8" at least!
http://s6.photobucket.com/albums/y21...t=P1010037.jpg
Old 09-12-2007, 02:22 PM
What trans are you dealing with?
Old 09-12-2007, 08:59 PM
The converter's not all the way in. The first time I installed a converter in a trans I went through exactly the same thing. Tried and tried to get it seated. Kept trying to bolt it to the motor. Not enough clearance. It took another half hour of wiggling and rotating the converter, coupled with extensive swearing, to FINALLY get it to seat. With the converter fully seated, you should barely be able to fit your finger between the converter and the back of the bellhousing. Any more clearance and it's almost certainly not seated.
One trick if the trans doesn't have any fluid in it is to stand the trans on end and drop the converter in vertically. Just be prepared - you'll be amazed at the amount of tranny fluid that can come out of an "empty" trans.
Old 09-12-2007, 09:07 PM
sorry, it's a 4L60E
I finally got it in though, apparently Edge had a batch of converters go out with a conical with super tight clearances, so it was having a hard time getting the o-ring from the input shaft into the conical. I had to put a ****load of lube on the o-ring and tap it with a rubber mallet when I got everyone else engaged.
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
Torque converter install connera Transmission - Rearend 7 05-16-2005 08:11 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
Torque Converter Problem Madhawk Transmission - Rearend 4 11-23-2004 08:35 PM
checking torque converter Tissue Transmission - Rearend 3 04-22-2004 08:23 PM
