Torque Converters - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2004, 07:00 AM
schuffm's Avatar
New Member
Question Torque Converters
I understand how a Torque Converter works, however i do not understand how interchangeable they may be? And i do not understand what it means when it mentions stall speed (or stall RPM) For example if i had an 8" 1500-2500 stall RPM torque converter and i want to place a 10" 2000-3500 stall RPM torque converter in its place. is this possible? does it matter on brand or what CID the engine is? how do i know if i purchase a torque converter that it is compatible and mountable to my flywheel?
I guess a little history with my problem would be needed here. I have a 1985 Firebird. it has a small 2.8 V6. When you press on the throttle you get high rpm's with little movement of the vehicle. Transmission fluid is at the correct fluid level. car shifts just fine when you shift through the automatic transmission range (including reverse although it doesn't have that "torque grab" feel to it anymore). also it will stall out at slow speeds. these symptoms started out minor then became worse as time went on. took almost a year for the complete degrade of the symptoms. because of the type of symptoms i am to believe my problem is the torque converter. any help on how to decide what type of torque converter to replace it with would be greatly appreciated
Old 10-30-2004, 10:54 AM
stu stu is offline
A torque convertor won't help you.
It is an internal seal/clutch problem.
Torque Convertors must come from the same family.
Old 10-30-2004, 01:21 PM
schuffm's Avatar
New Member
thank you for the advise STU i will look into it
