Torque convertor advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2005, 10:56 AM
Hi, I have just removed a chevy 305ci from my pickup and have a 350ci to go in it. My 350 engine has a 168tooth flexplate with staggered bolt hole starter motor. The 305 engine has a 153 tooth flexplate and straight hole bolt fixings on the starter.
I will be using the 168 tooth flexplate and staggered hole starter as the straight bolt starter from the 305 will not mount to my 350
The problem I have is that the th350 transmission has a torque convertor with the smaller mounting pattern (diameter) and will not bolt up to the 168 tooth flexplate.
I have a spare torque convertor from a th400 transmission that will fit the larger flexplate that I will be using, Would this fit ok in the th350 trans, it is slightly larger in size, or are the th350/th400 convertors not interchangeable?
I guess my other option would be to purchase a dual pattern flexplate and use the original convertor from the th350
Any advice would be appreciated
Thanks in advance
Rich
Old 05-03-2005, 07:59 AM
Crosley's Avatar
Wiki Edits: 1659
t-400 converter will fit a non lock t-350 tranny fine.
the 305 does not have a holes to bolt the wide pattern starter on?
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 09:21 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Torque Converters schuffm Transmission - Rearend 2 10-30-2004 01:21 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 08:04 AM
