torque convertor replace? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2010, 09:40 AM
gto_ron's Avatar
Hey group
I generally hang out on the body exterior forum but I have a question for you experts. I'm having the transmission rebuilt in my 87 Grand wagoneer. What about the torque convertor; do they wear out? Should it be replaced also?
thanks for any & all responses
Ron
64 GTO convertible
79 CJ7
87 Grand Wagoneer
Old 03-24-2010, 10:49 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
In all my years of driving, I've never had a torque converter failure.
If you cooked your tranny and its full of debris, then you'll need to change it for sure.
If it was running fine and you're just freshening it up, you could probably run it.
Old 03-24-2010, 12:38 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by gto_ron
Hey group
Ron
64 GTO convertible
79 CJ7
87 Grand Wagoneer
Some shops won't guarantee the tranny w/o a fresh TC installed at the same time. Cheap insurance, IMHO.
Old 03-24-2010, 01:04 PM
At least get if flushed
Old 03-24-2010, 01:29 PM
Rexnfx's Avatar
Hey group
Ron
64 GTO convertible
79 CJ7
87 Grand Wagoneer
With the AW4 transmission, I would say replace the converter. If you got enough miles on it to wear out that trans, then the converter owes you nothing
Also, depending on failure and contamination in the trans. The converter can't be flushed(with solvents) because it has a clutch in it. Besides, getting all the sediment out of it takes cutting it apart and running it through a nice cleaning machine. Wouldn't want the converter to contaminate the fresh trans would you? Same with the trans cooler, buy a couple cans of trans cooler flush, unless the shop has a cooler flush machine. But, like I said, it depends on type of failure the trans has had. But really, the trans rebuilder should be able to make a good judgement call.
Need a New Torque Wrench DTL504 Engine 33 10-25-2007 06:06 PM
torque converter banging??? Flywheel or tranny?? boneyard Buick Engine 5 09-04-2006 03:07 AM
flywheel torque = to flex-plate torque?? bullheimer Hotrodding Basics 2 05-26-2004 11:24 AM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 10:41 PM
Torque & HP for 355 SB Chevy bigjoedo Engine 7 04-17-2002 10:11 AM
