torque and horsepower - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2007, 11:11 AM
Last journal entry: Body work
We all know about parasitic horsepower loss through the drive train but, what about torque? How would the torque value from a chassis dyno at the rear tires compare to what is actually at the input shaft of the transmission. It almost seems like the differential gears would be like a torque multiplier. The reason I ask is the turbo motor in the rambler I'm building should produce around 650 horsepower and 600 ft lbs of torque at the rear wheels. The t56 transmission I'm using is rated for 450 ft lbs so, knowing the torque value at the crank would be quite useful. I know that dumping the clutch at 5000 rpm and power shifting will be out of the question.
Thanks. Ed
Old 02-19-2007, 11:39 AM
Horsepower is a function of torque over time.
HP = TQ * RPM/5250
So the horsepower loss through the drivetrain is actually a function of lost torque.
good Torque vs Horsepower article, put the debate to rest! ChevelleSS_LS6 Hotrodding Basics 13 07-30-2006 03:22 PM
Horsepower / Torque estimate? StevenC Engine 1 01-04-2006 07:44 PM
Automotive Manuals Horsepower and Torque SAE net figures change in 1972-73 Kid-lovin-his-52-Buick Engine 6 04-18-2003 09:20 AM
How much horsepower and torque you think i have? RiceMuncherdude Engine 15 03-13-2003 07:25 AM
horsepower & torque general Hotrodders' Lounge 0 10-06-2002 10:50 AM
