Torque-ing a crank pulley bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2010, 07:49 PM
Longboard's Avatar
Last journal entry: Well she is finally done!!!
Howdy, Well I blew the budget and bought a March serpentine system for my LS1 engine in my 61 Impala. The first piece is a new insert on the crank pulley. All is good except I can't torque it to the 90lbs because the engine wants to turn over. No other pulleys are on, no belt, nada. So how do I keep the engine from turning? I have settings on my air gun from 1 - 4, are any of those 90lbs? Anyone know what the settings are rated?
Much and often thanks!
Old 02-03-2010, 08:23 PM
MI2600's Avatar
Member# 3287
Have someone jamb the flywheel with a screwdriver.
Old 02-03-2010, 08:31 PM
Don't use the impact wrench, use a proper torque wrench. You can wedge the flywheel or use the factory flywheel retainer. I took a rusty crank pulley and welded a bar to it. Now I bolt this tool to the balancer and torque away.
Old 02-03-2010, 09:07 PM
OLNOLAN's Avatar
One Man Operation
Hey LB, For one man cooperation, use a curved jaw vise grip, clamped on the flywheel. Position it so the jaws bite on the fywheel and the curved part just clamps real lightly on the teeth of the flywheel. Turn the engine till the vise grips jam against the bell housing. Tighten the crank bolt till you reach required torque. Done deal. olnolan
Old 02-04-2010, 11:09 AM
Longboard's Avatar
As always, awesome buys, thanks!
harmonic balancer bolt torque? yragat Engine 9 10-20-2007 02:05 AM
Crank Pully Bolt and Timing Question 1970Chevy Engine 9 08-11-2007 01:11 PM
crank pulley dadsgp Engine 1 02-04-2003 09:59 PM
Crank Pulley not turning smuhammad Engine 1 01-22-2003 08:52 PM
12 bolt tabs for torque arm 85406 Transmission - Rearend 0 12-18-2002 11:59 AM
