Torque rating for 4-speed Saginaw - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2010, 08:01 PM
Anyone know how much torque a 4-speed Saginaw tranny can handle before it blows to pieces? Year is a 1973 or 1974.
Old 03-16-2010, 06:01 PM
It depends on the gear ratio...2.54 and 2.85 will probably hold up ok to 350 pounds of torque.The 3.11 a little less,the 3.50 is the weakest.The issue is shock loading like drag strip abuse.Saginaws hold up to 600 hp on dirt track car with no shock loads. And Saginaw front bearings get worn,the snap rings get loose so unless the tranny is in top condition it will blow up pretty quick with abuse.
Old 03-17-2010, 05:52 PM
Thanks for the feedback. Sounds like I shouldn't dump the clutch to often since I think I'm pushing 350 lbs of torque.
cosmichrome drchip Hotrodders' Lounge 19 12-28-2009 06:33 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Saginaw 4 speed with OD conversion. Hippie Transmission - Rearend 6 06-05-2008 10:10 AM
torque rating for a 80's T-5, tranny selection? hotrodf1 Transmission - Rearend 1 12-17-2003 10:34 PM
saginaw 3 speed od conversion slingslingbinks Transmission - Rearend 4 10-06-2003 02:07 PM
