To Torque to Re-Torque. That is the question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2010, 09:49 PM
Duntov's Avatar
Visit the NASCAR Hall of Fame
I want to turn this into a survey but lost the information on how to do it.
Question is...And we're talking GenI SBC for purposes of control; don't want to muddy the waters with confusion.
Do you torque down your heads and call it a day? What's your favorite color?
Do you re-torque your heads after heat cycle at least once? What's your favorite color?
Old 06-28-2010, 11:03 PM
4 Jaw Chuck's Avatar
I always re-torque, I don't care what the box says, usually after three or more heat cycles. The new gaskets don't lose the torque like they did in the old days but it seems they still lose a small amount like 5ft/pds so I still do it.
— Han Solo
Old 06-28-2010, 11:27 PM
sqzbox's Avatar
My pipes are my music
SBC, ford, mopar, yes. AMC no! Reason, 110-115 ft lbs of torque on AMC heads.
Old 06-28-2010, 11:43 PM
Silverback's Avatar
Boost Retard
blue and blue...
Old 06-29-2010, 07:36 AM
Duntov's Avatar
Started the retorque poll but need tech help
I finally realized how to create a poll on this re-torque issue. The link is below may or may not carry you there. could someone fix this for me? Thanks Duntov
Re-Torque Poll
Old 06-29-2010, 07:37 AM
sqzbox's Avatar
colors
Yeah, I forgot. BLACK AND BLUE. Thats what I was after torquing those AMC heads with an old style pointer torque wrench.
Old 07-13-2010, 07:50 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Modern engines? Torque and forget. Most of the latest engines use torque-to-yield bolts that can only be used once anyway. Don't like those!! Like most things, they are easier/quicker for the manufacturer to install (can use automated equipment), that's the main reason for them.
The only engine I know of that REQUIRES retorquing even with modern head gaskets is the old AMC/Rambler 196. DO NOT confuse this with the 64+ 199/232/258/4.0L -- they have no problems!
We (us AMC/Rambler guys) also figured out WHY it eventually loosens the head bolts! The head is rather massive for a small six and expands and contracts by 0.020" every heat cycle. That eventually backs the bolts out enough to blow the gasket -- running hot is the first indication, and the head usually warps a little. Now they are old (last one made in 65!) and have been run hot a few times already, so they have a nasty tendency to crack now, and good heads are getting hard to find.
This engine is a flat-head conversion. The head can't be bolted to the old flat-head block because AMC changed the right side of the block casting where the valves were in the flat-head. From the top of the side covers down and on the left side of the block it's identical to the flat-head, but that top right side is different and the bolt pattern for the head is different. The head has the intake built in with an aluminum cover plate. The large mass of cast iron alone is what causes it to loosen the bolts over time. Has to be retorqued every other year/12-15K miles or it will eventually blow the head gasket. Don't know how long/far it will go, but the valve cover has to come off to adjust the solid valves at about those intervals anyway.
Torque Converter Question newbielike Transmission - Rearend 2 12-17-2007 05:53 PM
Torque Converter Question leejoy Transmission - Rearend 5 10-02-2006 11:57 AM
Torque converter question. gavinpierce Hotrodding Basics 1 02-15-2006 09:53 AM
Hotrodders Guidelines -- READ ME Jon Suspension - Brakes - Steering 0 06-14-2003 05:03 PM
Hotrodders Guidelines -- READ ME Jon Electrical 0 06-14-2003 05:01 PM
