Torque Settings-Differential - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2003, 07:44 PM
dollybud's Avatar
I've checked around and everyone seems to have different settings:
- what is the correct torque for the 12 bolts on the ring gear? (ft/lbs)
- what is it for the 4 carrier bolts? (ft/lbs)
- what is the pinion preload initial and final? (inch/lbs)
This is for 4.10 gears in a GM 12 bolt posi with ALL NEW bearings, thanks in advance.
Tom
Old 12-23-2003, 11:51 AM
Check ring-pinion.com, they have a page with this info.
