torque on shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2005, 10:29 AM
j o j o is offline
torque on shocks
does anybody know how much lb torque to apply when installing shocks.I have been tod anything from 10 lb to as tight as you can get. thanks JO
Old 12-02-2005, 11:24 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Some shocks come with a smaller bolt on top than on the bottom. Thus different torque. Max torque specs for bolts depending on size, grade, and pitch can be found here.
Old 12-03-2005, 02:13 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
K.I.S.S.
For bolts that go through laterally= the nuts only hold the bolts in and the shock usually has a metal tube the bolt goes through.= 25 is fine.
For stud type shocks with the "bolt" longitudinally= uses donuts = compress the donuts until a slight amount of "fatness" is seen, and lock the nuts there. I like double nutting with a self locking nut. (same for anti-roll bar end links)
Exhaust Diameter Formula ChevelleSS_LS6 Engine 11 04-27-2012 10:21 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Torque Converters schuffm Transmission - Rearend 2 10-30-2004 02:21 PM
Is 2 1/2 pipes big enough? Mustang_Killa66 Engine 7 02-12-2004 09:04 AM
