Torque spec on BBC oil pump? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2009, 09:51 PM
540neverdone's Avatar
Loves to spooge
Misplaced my books, whats the torque spec for the oil pump stud on a BBC?
Old 05-01-2009, 11:37 PM
Speedshift_Sam's Avatar
Mekanicus Automotive Group
BBC specs
Well, that really depends on what you go by. Haynes manuals usually understate the TQ specs, Chilton's manuals leave out the details, Motors manuals are about the best you can get, but from working on Helicopters and airplanes, I can safely say that the standard TQ spec on a 1/4" corse thread oil pump bolt is 40 foot pounds. 50-60 on a fine thread. But then again, this is something that won't leave the ground, so if you feel confortable at 40, or 50, use it. The factory manual calls for 45 depending on the year, make, model, and whether it had 4 bolt mains or not, but automotive work is not an exact science, 40 is a good bet, it has served us Curley boys well for 30 years on our SBC and BBC race engines of various sizes, types, and configurations.
Old 05-02-2009, 06:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Oil pump bolt (7/16-14) to cap is 65 ft/lbs.
Old 05-02-2009, 05:19 PM
Loves to spooge
Hmm, 40-65lbft is a pretty wide range.
Old 05-02-2009, 07:36 PM
GMC boogie's Avatar
It is 65 ft lbs....no doubt about it.
Old 05-02-2009, 09:31 PM
Loves to spooge
Thanks guys, its an ARP stud, Im sure can handle 65. Thanks again.
Old 05-03-2009, 12:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
ARP says 71 ft/lbs for a 7/16" stud- lubed w/30W oil.
If lubed w/ARP moly, the torque required to get the 1270 lbs. preload is 56 ft/lb.
Bolts are 2 ft/lb more for either type lube.
Old 05-03-2009, 03:18 PM
Loves to spooge
Cobalt is there a site you can use to verify torque on ARP fasteners?
Old 05-03-2009, 03:30 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The torques I quoted are from an ARP catalog. I don't know of a web site.
Name:	use torque 001.jpg
ID:	38001   Click image for larger version
Name:	use torque 003.jpg
Old 05-03-2009, 06:31 PM
Loves to spooge
Thanks, didn't doubt you, just thought I wouldn't have to bug you again if I knew!
Thanks Again
Chevy 6.5 Diesel has no oil pressure again!!! dorksrock Engine 12 09-02-2012 08:51 PM
Melling M155HV Oil pump? mrdreex Engine 34 06-26-2010 07:18 PM
Oil pump ? 70gmcer Engine 9 11-20-2005 01:01 PM
SBC oil pump shaft Richs66chevelle Engine 6 10-30-2005 12:19 PM
