Torque Specifications for converter to flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-17-2010, 03:41 PM
Looking for Torque Specifications for a torque converter to the flex plate on a Dodge Motor Home. Engine, 440 Transmission is a chrysler 727 automatic?
Thanks
Old 06-17-2010, 06:54 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
RB/B Engine Torque Specifications Big Block Chrysler 383, 400, 440
* Torque values shown are in ft/lbs unless otherwise noted
* Follow factory torque sequence
Fastener Torque Thread Size
A/C Compressor to Engine Bolt 30 3/8-16
Alternator Adjusting Strap Bolt 200 in/lbs 5/16-18
Alternator Adjusting Strap to Block Bolt 30 3/8-16
Alternator Mounting Bolt 30 3/8-16
Camshaft Lockbolt 35 7/16-14
Carburetor to Manifold Nut 7 5/16-24
Clutch Housing Bolt 50 7/16-14
Connecting Rod Nut - Plain 45 3/8-24
Crankshaft Rear Seal Retainer 30 3/8-16
Crankshaft Bolt (Vibration Damper) 135 3/4-16
Cylinder Head Bolt 70 7/16-14
Distributor Clamp Bolt 15 5/16-18
Exhaust Manifold Nut 30 3/8-16
Exhaust Pipe Flange Nut 50 7/16-20
Exhaust Pipe Clamp Nut 20 3/8-24
Fan Attaching Bolt 15-18 5/16-18
Flywheel Cover Bolt 7 1/4-20
Flywheel Housing to Block Bolt 50 7/16-14
Flywheel to Crankshaft Bolt 55 7/16-20
Fuel Pump to Block 30 3/8-16
Intake Manifold Bolt 40 3/8-16
Main Bearing Cap Bolt 85 1/2-13
Oil Pan Drain Plug 20 1/2-20
Oil Pan Bolt 15 5/16-20
Oil Pump Cover Bolt 10 5/16-18
Oil Pump to Block Bolt 35 3/8-16
Rocker Shaft Bolt 25 3/8-16
Spark Plug 30 14mm
Starter Mounting Bolt 50 7/16-14
Timing Cover Bolt 15 5/16-18
Torque Converter Housing Bolt 30 3/8-16
Torque Converter to Flexplate Bolt 270 in/lbs 5/16-24
Valley Pan End Bolt 9 1/4-20
Valve Cover Stud & Nut 7 1/4-20
Vibration Damper Pulley Bolt 200 in/lbs 5/16-20
Water Pump to Housing Bolt 30 3/8-16
Water Pump Housing to Block Bolt 30 3/8-16
Hope this helps.
Cole
Flywheel and clutch advice for 383 stroker v8hed Transmission - Rearend 4 03-19-2010 05:09 PM
Need emergency advice on rod bolt torque issues. eric32 Engine 11 05-27-2009 05:41 PM
Flywheel Swap / Engine balancing HP52TA Engine 8 04-10-2009 05:18 PM
350 HO Flywheel m007gunit Transmission - Rearend 3 12-10-2007 12:29 AM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 10:41 PM
