Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - torque specs
Thread: torque specs
Old 01-11-2013, 02:15 PM
327NUT's Avatar
327NUT 327NUT is offline
I recommend using the specs the bolt mfg. gives you in the paperwork. Some guys use a bolt stretch gauge on the rods and some just use the stock specs. If you're using stock rod and main bolts then use the stock specs. Also a lot depends on what lubricant you're using coat the threads. What bolts and lube are you using?
