id go by ARP's specs,they are far stronger than grade 8 bolts and making strong bolts is what they do.There proffesion depends on how well there bolts perform so they have to test and come up with there specs for each bolt and application.not tring to sell em off but they are supposed to be very good.well thats my two cents.Good luck
Blag |
First, the 170,000 psi bolts I have seen are not stainless. I am not sure of the tensil strength of stainless, but it is less than 170,000 I believe.
Never the less, the torque specs are for the nut. You first screw the stud into the head hand tight. You will probaby have to chase the threads with a tap first so they screw in easily. Then install the nut and torque them down. Also, I think you will find it impossible to get a torque wrench on all of the bolts. If you cant, just get them good and tight and check them periodically. Chris |
Ok, thanks a lot for that info, we're putting them in tonight. I got the torque specs from ARP's website. The studs are 3/8" stainless steel.
Here's the material specs: http://www.arp-bolts.com/pages/tech/matspec.html Here's the torque specs (look out, it's a PDF): http://www.arp-bolts.com/pages/tech/images/fasttorq.pdf I'll do what you said, tho, Turbo, thanks for the help. |
Cool, I had no idea that stainless bolts exceeded grade 8 in strength. I must say that is probably exclusive to ARP's bolts. I think the cheapos are not nearly as high.
Chris |
