-   -   torque specs (http://www.hotrodders.com/forum/torque-specs-228263.html)
kentactic 01-11-2013 02:02 PM
torque specs
Are the stock rod/main cap torque specs still good on a SBC stroked 383? If not what do you recommend?
327NUT 01-11-2013 02:15 PM
I recommend using the specs the bolt mfg. gives you in the paperwork. Some guys use a bolt stretch gauge on the rods and some just use the stock specs. If you're using stock rod and main bolts then use the stock specs. Also a lot depends on what lubricant you're using coat the threads. What bolts and lube are you using?
kentactic 01-11-2013 02:28 PM
ARP bolts. I didnt think to open the box and read stuff ha... I guess ill see what i find in the box. Im not use to the part coming with any useful information.
