torque specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2013, 02:02 PM
torque specs
Are the stock rod/main cap torque specs still good on a SBC stroked 383? If not what do you recommend?
Old 01-11-2013, 02:15 PM
327NUT's Avatar
I recommend using the specs the bolt mfg. gives you in the paperwork. Some guys use a bolt stretch gauge on the rods and some just use the stock specs. If you're using stock rod and main bolts then use the stock specs. Also a lot depends on what lubricant you're using coat the threads. What bolts and lube are you using?
Old 01-11-2013, 02:28 PM
ARP bolts. I didnt think to open the box and read stuff ha... I guess ill see what i find in the box. Im not use to the part coming with any useful information.
Bellhousing bolts and torque converter bolts torque specs Davey3ch Transmission - Rearend 2 09-04-2009 11:05 AM
torque specs mac350 Engine 3 06-26-2006 07:10 AM
Torque specs... sbchevfreak Engine 1 05-31-2005 09:34 PM
torque specs Terry411 Engine 6 01-04-2005 08:53 AM
Torque Specs Phyrkrakr Engine 5 07-25-2003 07:54 PM
