torque specs for 351c - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2010, 08:31 AM
I have what appears to be a 351c. I just wonder now if its a 2v or a 4v. The 2v's were more common (92%) used in grocery getters while the 4v's were the high-perf mills. I just want to id it and take the heads off to clean it up before I try to sell it. It came in the back of a truck I bought. The seller said the extra engine came out of a wrecked car and it was fine except for the fact that it has been sitting outside. I thought if I could take the heads off, I could spray some WD-40 on the cylinder walls and turn the crankshaft a bit. I also want to take the head(s) off to measure the valve diameter. That would for sure tell me wheather its a 2v or a 4v. If its a 4v then I'll ask more for it. From what I've read the 351c-4v is not much on low-end torque and only really comes to life when you get to about 6 or 7 grand. The casting no. is D7TE A2B which doesn't tell me much. I have some pics I will try to post here.
ID:	46546   Click image for larger version
ID:	46547   Click image for larger version
ID:	46548   Click image for larger version
ID:	46549   Click image for larger version
Old 07-02-2010, 12:58 PM
majorownage's Avatar
this is not a cleveland. It is a either a 400 or 351 "M" It's a derivative of the Cleveland. Unfortunately, they only came in 2v configuration. It would be a great engine to rebuild with cleveland 4v heads.
These engines are as common as the sand. I would be surprised if you got 25 bucks. :/
Old 07-02-2010, 01:03 PM
btw all the people that say the 4v has no low end torque have never built a 4v cleveland. Pick the correct cam and intake and you are fine.
With a 4v cleveland, all it takes to make 500hp is a lumpy cam and a holley strip dominator and you will make 500hp around 6300 rpms....
No porting or other mods necessary!
Old 07-02-2010, 01:33 PM
Well, I don't mind giving it away - but - if there's a chance that I can make a hill-climber out of it, I'll keep it in case the 400 I've got in the truck now takes a dump. I'll have to find the numbers on the engine I've got in it now. BTW the tag on the valve cover of the extra engine says 351c 5.8L. It has some other stuff, I'll have to look again. I was told it was a 351c but you be the judge.
Old 07-02-2010, 01:40 PM
dead giveaway that it is an "M" smogger:
"D7" That stands for 1977; the year it was cast. No cleveland was made after 73...
After some research, the A2B seems like it stands for the 400 ci version....
Old 07-02-2010, 01:42 PM
A smogger, huh. I guess I'll put an add on craigslist then. Thanks.
Stud torque specs for SBC heads? pittbull7934 Engine 9 08-08-2009 05:32 PM
3.1 litre torque specs boatanchors Engine 1 02-13-2009 05:14 PM
i need the torque specs inline 6 235 chevyInline6 Hotrodding Basics 4 02-09-2009 10:23 AM
Suspension torque specs scr8pin_f100 Suspension - Brakes - Steering 3 12-31-2008 06:46 AM
Torque Specs joeford Hotrodding Basics 2 11-05-2006 05:54 PM
