torque specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2006, 01:36 AM
mac350's Avatar
http://www.eastcoastfbody.com/
torque specs
i am installing a set of heads on my 350 and i need to know if any one has the torque specs for the head bolts. the Head i am putting on are aluminum vortec. any help would gladly be appreciated.
Old 06-26-2006, 12:49 AM
65lb-ft, but not all at once. Start with 30 all the way around the sequence, then 40, then 50, then 60, then 65.
And don't forget to use washers under the bolt heads with aluminum heads.
Old 06-26-2006, 07:12 AM
mac350's Avatar
thanks for the info i should be putting them on any day know. i will let you know how i goes
Old 06-26-2006, 08:10 AM
re: torque specs
also note that the intake uses a lot less torque, I think 10ft lbs depending on the intake
Help with the torque specs Kevin45 Engine 6 03-23-2005 03:51 PM
Anybody have wheel torque specs? TurboS10 Hotrodders' Lounge 5 03-08-2004 03:08 PM
Torque Specs Phyrkrakr Engine 5 07-25-2003 08:54 PM
Torque Specs...Engine Builders TurboS10 Engine 10 03-08-2003 03:21 PM
VETTE REAR END TORQUE SPECS reegeemon Transmission - Rearend 1 12-23-2002 03:32 PM
