Torque Specs for BOP TH350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2006, 03:06 PM
Hey does anyone have the torque specifications for the th350 bellhousing to engine block, and torque converter to flexplate, and those little driveshaft U-bolts. Thanks a lot
Mark
Old 05-10-2006, 05:54 PM
airworld2's Avatar
just use a good 1/2 drive impact for the bell
lock tight the converter screws
u joint bolts tighten by hand but use good force(don't use hulk force)
but answer the question you ask I never looked the setting up for this 28 years doing transmission repair never drop a tranny out from loose bolts I put in....
Torque Converters and TH350 problems adventureseeker Transmission - Rearend 10 06-06-2005 04:20 AM
Anybody have wheel torque specs? TurboS10 Hotrodders' Lounge 5 03-08-2004 02:08 PM
Torque Specs Phyrkrakr Engine 5 07-25-2003 07:54 PM
Torque Specs...Engine Builders TurboS10 Engine 10 03-08-2003 02:21 PM
VETTE REAR END TORQUE SPECS reegeemon Transmission - Rearend 1 12-23-2002 02:32 PM
