Torque specs for Cast Iron block, but Aluminum engine componets - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2008, 07:27 PM
J-Garden's Avatar
Ready to start building on my 454 block my question involves the top end proportion of the build. I'm putting on an Edelbrock top end kit(everything obviously consisting of aluminum.
http://store.summitracing.com/partde...5&autoview=sku
I eed to know which specs to go with eith the Cast Iron specs or the Aluminum block specs below. Any help on this would be greatly appreciated.
Chevrolet Big-Block
Iron Engines
Component Torque
Camshaft Sprocket Bolts 20 ft. lbs.
Cylinder Head Bolts Long 70 ft. lbs.
Short 70 ft. lbs.
Cylinder Head Studs Long 65 ft. lbs.
Short 65 ft. lbs.
Exhaust Manifold 20 ft. lbs.
Flywheel Bolts 60 ft. lbs.
Front Cover Bolts 75 inch lbs.
Intake Manifold 25 ft. lbs.
Main Bearing Bolts Inner 110 ft. lbs.
Outer 110 ft. lbs.
Oil Pan Bolts 165 inch lbs.
Rocker Arm Studs ( All ) 50 ft. lbs.
Rod Bearing Bolts ( 7/16in.) 67-73 ft. lbs.
Valve Cover Bolts 25 inch lbs.
Chevrolet Big-Block
Aluminum Engines
Component Torque
Bell housing 25 ft. lbs.
Cylinder Head Bolts w/Hardened Washer Long 70 ft. lbs.
Short 70 ft. lbs.
Short 60 ft. lbs.
Rocker Arm Studs ( Aluminum head ) 50 ft. lbs.
Valley Studs (4) 50-55 ft. lbs.
Source: http://members.tripod.com/torquespecs/hi_po_chev.htm
Old 09-18-2008, 11:39 PM
Why not listen to the ones that know best, the cylinder head manufacturer??
http://www.edelbrock.com/automotive_...6000/60449.pdf
crate chevy 302? Vancouver Grand Prix Hotrodders' Lounge 106 12-31-2012 05:05 PM
Build for Hp or Torque? Venturat Engine 76 09-23-2008 11:22 AM
Engine build question here n-gin Engine 10 06-11-2008 07:04 AM
Newbie... and Caddy v8 4100 question KYLEdallas Engine 31 11-18-2005 12:16 PM
Torque Specs...Engine Builders TurboS10 Engine 10 03-08-2003 03:21 PM
