Torque Specs Chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2006, 09:29 AM
Knuckles El Creep's Avatar
62 Studebaker Lark w/Chevy 350
Hi I need to know the torque specs for the rocker arms on a small block Chevy 350. Is there a certain pattern? I've seen specs on the rocker studs but nothing on the rocker arm nuts. I've also heard something about tightening them until there is no more play in the push rod, and then 3/4 turn. In what direction I dont know.
Old 04-28-2006, 09:53 AM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Good place to check out:
http://www.boxwrench.net/specs/chevy_sb.htm
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 04-28-2006, 07:04 PM
HUH?'s Avatar
Rocker arm adjustment
You can adjust hydraulic lifters with the motor running or not running. You
will need some sort of oil control device to do it with the motor running. The
most accurate way with the motor off is one cylinder at a time with the
cylinder on the compression stroke. There is also a way to do part of the
valves then rotate the engine 360 degrees and do the rest. That method
escapes me. (Can anyone refresh me?) The adjustment is the same in all
cases. Find zero lash and tighten 1/2 to one full turn more.
http://www.picturetrail.com/yelrah_dave
Old 04-28-2006, 10:36 PM
Siggy_Freud's Avatar
If you do a search in the knowledge base or using the search function on adjusting rocker arms, you'll find all you need to know on it. If you still have questions, come back and ask .
Dylan.
Bringing history and technology together.
Old 04-29-2006, 02:09 AM
malc's Avatar
Living At The Speed Of Life
This is the method I use.
Old 04-30-2006, 09:56 AM
small block chevy
Hey dude, it has been years since i worked in chevy dealership but i prefered engine work when i was there. I did it so much i got lazy and would run the nut down about a half inch in each stud. Regaurdless of which pistion was up, knowing that about half thread is what itis going to end up with anyway. From that point the valves were tight enough to allow the engine to run but i had chatter on all the rockers. Then i would turn then slowly crank down until the engine started missing, At that time back off just a little and leave it there. move on to the next. (this only works if you have hydrolic lifters that have been pumped up) this is the fasted way i found.
Old 04-30-2006, 10:10 AM
malc's Avatar
Are you a technical writer for Haynes or Chiltern ?
Old 04-30-2006, 11:45 AM
malc's Avatar
For HUH?, set the number one cylinder at TDC firing position and set the exhaust valves on cylinders,1, 3, 4, 8 and the intakes on,1, 2, 5, 7.
Rotate the crank 360š and set the exhaust valves on cylinders, 2, 5, 6, 7 and the intakes on, 3, 4, 6, 8.
According to Chiltern, Haynes left out number 1 cylinder in theirs.
BTW for Chevy.
Edit: Preload, Chiltern says 1 1/2 turns in and Haynes reckons 1.
Old 04-30-2006, 07:06 PM
HUH?'s Avatar
Thanks malc
malc,
Thanks for your reply on setting valve lash. Your method is fast and
plenty accurate enough for hydraulic lifters. When you pass fifty years of age
you lose many things. Memory is usually the second, I can't really remember the first!
Dave
Old 05-01-2006, 11:48 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Obvioiusly most people are concentrating on lash adjustment.
The rocker arm nut still requires TORQUE.
If the self-locking nut has insufficient torque the adjustment will not stay constant.
Look for about 10-15 lb/ft torque on the nut-to-thread drag.
Old 05-01-2006, 12:22 PM
malc's Avatar
Donīt you mean rocker arm stud ?
Old 12-15-2012, 04:46 PM
I think he's talkin' about the nuts. If the torque is less, replace the nut as the self locking feature has been compromised.
Old 12-15-2012, 08:27 PM
327NUT's Avatar
Hey st3.....good info but the thread is 6 yrs old.
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
Turbocharging a 350 chevy radracer43 Engine 4 09-25-2005 07:30 PM
torque specs for a flex plate on a chevy 350 to auto tranny badk5 Engine 1 07-01-2005 06:56 AM
torque specs. , 88' chevy 350 leonard69 Engine 1 05-27-2005 11:30 AM
