torque specs for my clutch and flywheel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2007, 02:23 PM
What are the torque specs for my clutch and flywheel for my 1973 Chev 1/2 ton with a 350 engine and four speed transmission?
Old 06-23-2007, 10:43 PM
brian0605's Avatar
mostly confused
Last journal entry:
flywheel is 60ftlb, the clutch 35ftlb. Here is a good link save it to your favorites!! http://boxwrench.net/specs/chevy_sb.htm Brian
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
1986 Iroc 5 spd Flywheel and Clutch > Fit's 4.3?? boneyard Buick Engine 3 11-06-2006 08:11 PM
M21 to M22 - clutch and flywheel help DarwinBrooks Transmission - Rearend 13 02-08-2006 05:33 AM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 06:44 PM
clutch disc springs hit flywheel bolts 72chevy240z Transmission - Rearend 6 05-05-2004 02:21 PM
