torque specs for polygraphite LCA bushings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-20-2005, 11:51 PM
New Member
does anyone know where i can find them?
i've got a '67 Mustang that i'm working on, and i know that if i use the torque specs for the stock rubber bushings it'll tear the poly ones up
Old 09-21-2005, 03:08 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Check with your bushing manufacturer. I have changed two cars over to poly and used stock specs, never had a problem that I knew of. Lube them well with synthetic grease during assembly to eliminate squeaks, and when you are ready to torque have the vehicle's weight on the suspension. Don't let the wheels hang when you torque the mounting bolts.
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
Anybody have wheel torque specs? TurboS10 Hotrodders' Lounge 5 03-08-2004 02:08 PM
Torque Specs Phyrkrakr Engine 5 07-25-2003 07:54 PM
Torque Specs...Engine Builders TurboS10 Engine 10 03-08-2003 02:21 PM
VETTE REAR END TORQUE SPECS reegeemon Transmission - Rearend 1 12-23-2002 02:32 PM
