Torque specs for pressure plate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2006, 07:18 PM
I am installing a new clutch, pressure plate and throw out bearing in a Chevy 350, 260 hp, street driven engine connected to a Muncie 4 speed transmission. Zoom, stock type clutch and pressure plate.
I can not find torque specs in my service manual for the pressure plate.
Does anyone know what it is?
Old 09-21-2006, 07:46 PM
nitro_baller4692's Avatar
floppers forever
you should post this in the trans and reaend forum.you'll get replies there.but i would think around 45 pounds.i just tighten them but i know every bolt has a torque spec.i never had a problem but them maybe i'm just getting lucky.
Old 09-21-2006, 07:48 PM
GMC boogie's Avatar
I have never torqued them. I get them good and tight with a 3/8 drive ratchet. They are 3/8 bolts so I would think 35-40ftlbs would be sufficient.
Old 09-21-2006, 10:15 PM
327NUT's Avatar
I just looked it up, says 35 lbs. with thread locker.
Build for Hp or Torque? Venturat Engine 76 09-23-2008 10:22 AM
torque specs Terry411 Engine 6 01-04-2005 08:53 AM
BBC torque specs Hooter Engine 2 09-20-2003 08:44 AM
Anyone have any Max capable Torque specs for chevy T5 trannies? FroFro Transmission - Rearend 1 08-08-2003 01:23 PM
Torque Plate Hone TurboS10 Engine 12 12-28-2002 03:13 PM
