Torque Tube Axle switch - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2006, 09:53 AM
Currently needing to change 4:11 rear in a GM 50' 3100, to 3:55. I have paid deposit on a PG diff, to install in PU. Can I just pull the horsehoe clips, and swap the 6 lug axles to the 5 lug, from the PG, after I get it installed, so I can keep the 6 hole 16" wheels and tires.
Old 03-27-2006, 03:20 PM
Wiki Edits: 49
I think we need a more detailed explanation of what you're trying to do. What is a PG differential for one thing. I've never heard of it.
Old 03-27-2006, 03:50 PM
I believe a PG differential is one from a PowerGlide equipped vehicle..... But I also believe he is trying to put a car rear center section under a truck.... and I do not believe it will work......but I could be wrong......
Like Centerline says.........more information is needed...
Old 03-27-2006, 04:33 PM
Wiki Edits: 31
The 2 rear ends are 2 diffrent widths to my knowladge, custom axles would be needed. Yes I also belive the PG refers to the powerglide equiped cars, as they have 3.55 gear rear ends in them.
Old 03-27-2006, 07:39 PM
Wiki Edits: 49
If he is referring to a Powerglide rear then it's really no different than any open rear. If he's keeping the original 6 then he'll need to change the trans and driveshaft to an open unit that will be compatible with the rear he's using. You can't just throw in an open rear on those old trucks without changing the driveline to match.
Old 03-27-2006, 08:16 PM
you can do this swap
For the best advice go to www.stovebolt.com and look either under tech tips or FAQ--I can't remember where the details of this swap are. I do know you have to disassemble the carrier and swap side carrier gears because the truck and car axle shafts are different. I think you also have to swap torque tubes as well but again my memory fails me.
I have a 51 Chevy half ton I have been SLOWLY working on for the last few years and I have picked up a LOT of good info from the Stovebolt page--tell'em Racecarl sent you!
Old 03-27-2006, 10:10 PM
PG rearend,
Hey, thanks guys for all the response, the PG rearend is an enclosed drive line, from a powerglide car, prior to 55, chevrolet, which has 3:55 gears. What I want to do, to keep the 6 lug axles is just slide out the 5 lug on the PG rearend, and install my 6 lug axles. I had a 52 Belair that had been so changed, and it ran 65-70 effortlessley, not wound up tight as with the 4:11. at 50 mph. I am keeping it origional, with the 216 engine, and standard 3 spd. just trying to improve roadability. It should work unless the splines on the Pu axle are different.
Old 03-28-2006, 07:05 AM
Wiki Edits: 49
That may not be quite as involved as I mentioned earlier. Wasn't aware of the enclosed PG rear ends. Hay, I'm a Mopar guy....
Old 03-28-2006, 02:51 PM
Wiki Edits: 31
I think '53 up Powerglide cars are open drive. my '51 Chevy w/ powerglide has a torque tube
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Leak from diff. to axle tube? schnitz Transmission - Rearend 6 11-24-2005 12:06 AM
Cadillac Engine for a rambler? Farthingfan Hotrodding Basics 10 09-17-2005 09:44 PM
Straight Axle and Rack & Pinion Murff Suspension - Brakes - Steering 12 06-15-2004 03:21 AM
Torque Converters: Do They Multiply Torque? purple1967camaro Transmission - Rearend 1 04-28-2004 10:41 PM
