torque wrench question - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-11-2012, 10:31 PM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so I know nothing about torque wrenches&I know I need to learn.I have something that has to be tightend down to 72 in lbs 12 in lbs @ a time.But all of the torque wrenches I find start off @ 5 ft lbs or 20.Sorry so green on this but please any help would be great!
Old 02-11-2012, 11:32 PM
vncruiser's Avatar
Gearhead
Forget finding torque wrench with lb/in at Sears. Try a tool supply house in your area. Or look online to locate one.
Old 02-11-2012, 11:49 PM
two cups of tea
Wiki Edits: 2
Yeah Ive been looking online the problem is I cant find one that will do 12 ft inches is 1 ft lb only 5 ft lbs&up is what I can find.
Old 02-11-2012, 11:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Craftsman makes a 25-250 in/lb. torque wrench. But to get the first 12 in/lb. increment would take a wrench w/more range than one starting at 25 in/lb.
Is this some kind of precision assembly? For the best accuracy you'd like a tool that had a range that puts your final torque value near the mid point of the tools range. That would be a wrench w/a 150 in/lb capacity in your case, although the 250 in/lb wrench will work for most cases. I have 1/4" drive torque wrenches that would work well, but you might find the cost high for the limited use you will likely ever have for one.
Old 02-12-2012, 12:05 AM
two cups of tea
Wiki Edits: 2
What Im gonna be using it for is to replace my plenum gasket&install a new belly pan on my dd&the specs say when putting the intake back on it has to be torqued down 48 inch lbs in 12 in lbs incraments.Now on my other car with my performer intake I just make sure there snug but I was told itz important to do this ine to spec.So Im looking
Old 02-12-2012, 12:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Torque wrenches w/that kind of range are also used in the auto industry for setting up steering gears and setting differentials up. Thing is I wouldn't expect anyone to loan out their tools.
I doubt the parts stores have that small of a torque wrench to loan out, but you might give them a try.
Old 02-12-2012, 12:19 AM
two cups of tea
Wiki Edits: 2
Just noticed I out a g instead of an h in wrench.Anyways I will be looking for one.Ill try the parts store&look more online.Seems crappy to buy one I may not use much.But hey thats life right!
Old 02-12-2012, 06:46 AM
topwrench's Avatar
Last journal entry: fish carb
If u know anybody that works on Cummins engines (Bigger engines) like the old ntc350 etc. they will have one.It is used to set the injectors,I have a Snap On dial indicator wrench that would fit your needs,If I was closer Id loan it to u.
Old 02-12-2012, 07:19 AM
Guys I just googled inch pound torque wrench and came up with dozen of sellers. Prices under $30. Amazon. No problems
Old 02-12-2012, 08:47 AM
Shelby1's Avatar
Steel Dreams
Try auto transmission repair shops...there are parts of auto trans that require torque specs in that range....might work a deal with one of them....just a thought..
Good Luck!
Kenny
Old 02-12-2012, 09:30 AM
two cups of tea
Wiki Edits: 2
Sure dont but thanks
Old 02-12-2012, 09:31 AM
two cups of tea
Wiki Edits: 2
thanks jusr wnt on amazon&searched&found one
HF Torque Wrench mafiacustomz Garage - Tools 72 01-12-2011 07:50 AM
torque wrench help please. yasmany Engine 9 12-06-2009 06:08 PM
Torque Wrench Question wretched ratchet Garage - Tools 4 04-29-2008 10:10 PM
Getting a Torque Wrench? Ayh127 Garage - Tools 36 03-15-2008 08:31 PM
Torque Wrench johndoe Garage - Tools 4 10-13-2004 06:37 AM
