Torqueflite 904 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2007, 08:03 AM
Billvill's Avatar
The spedo cable at the transmission has a large nut attaching it to the drive housing. A pair of water pump pliers work well. If you have to you can unbolt the spedo drive from the transmission. 1 7/16 bolt that holds a Y bracket. Then just pull the spedo drive straight out.
The shift and TV (kick down) linkage rods are a clip or maybe a cotter pin in 65 . If you have to you can unbolt the actual levers from the valve body. Just unbolt both of them and pry them straight up.
I hope that helps
