torqueing brake lines / Shackles - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2003, 07:28 PM
What is the proper torque for brake lines, Ive heard 15lbs, but how can I measure tightening with a open end wrench? Also when I tighten down my rear shackles should I tighten them up until the center bolt starts to draw each side in a little? What is tooo much, thanks, Dana
Old 11-25-2003, 07:31 PM
poncho62's Avatar
Wiki Edits: 5
Tighten your brake lines until they don't leak. The shackles should be quite tight. Not sure how much.
Ontario Rodders
Old 11-26-2003, 05:11 PM
thanks!
