torquing con rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2012, 06:21 PM
theg's Avatar
torquing con rods
Hello all .
Wondering when torquing up conrod bolts to crankshaft do the rods need to be supported in any way or just let the twist load apply onto the bearings .
Old 02-20-2012, 06:28 PM
BOBCRMAN@aol.com's Avatar
Few builders are concerned with this. If you are. Use the correct feeler gauge between the rods to eliminate side twist while torquing.
Old 02-20-2012, 07:11 PM
Richiehd's Avatar
JS-70
torque, loosen, retorque to specs
Old 02-21-2012, 08:21 AM
Use a minimum of .010" feeler blade. It must be hardened steel (NOT the brass one). "Whack" the rod pair back and forth a couple times with a soft hammer (we use plastic so no debris comes off). Place the blade between the rod and the crank, where, when you turn to torque, the pressure is against the blade and the crank. When it "snaps" torque, move to the next bolt. "Torque" all the rod bolts (both rods) twice while you're "there" (don't loosen them, just hit them again). This will "square up" the rods to each other, a MOST important aspect of a good build. Educated builders are VERY concerned with this.
Jim
Torquing aluminum pan Cape Cod Bob Transmission - Rearend 1 08-26-2009 12:57 AM
Need suggestion for torquing cam bolts with roller button. eric32 Engine 4 07-28-2009 07:50 PM
head torque specs/angle torquing curtis73 Engine 7 05-02-2009 12:35 PM
Torquing center support in TH400/4L80E bugsdad Transmission - Rearend 21 04-10-2005 10:53 PM
Torquing Aluminum Heads vs. Iron??? camaroman7d Engine 1 02-22-2004 03:52 PM
