torrington bearing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2007, 12:05 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
torrington bearing
I already checked the archives.
I just bought a new nine key cloyes timing set with torrington bearing. The instructions as well as the website does not cover the bearing. It is the style that does not require block machining.
Question
Which side of the bearing faces the block?
Old 05-20-2007, 07:38 AM
Rogers Performance's Avatar
The open part to the cam gear the closed or wide side to the block.
Old 05-20-2007, 07:51 AM
bracketeer's Avatar
489 Lemans
thankyou, i couldn't find that information anywhere
Pilot Bearing / Solid or ballbearing type"whats best to use" x711 Transmission - Rearend 16 01-10-2007 09:03 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 02:29 PM
tiny little fish-scale-like flakes of bearing on bearing/journal bullheimer Engine 2 04-16-2004 02:12 PM
Cam Bearing Oil Hole DTL504 Engine 2 03-05-2004 11:39 PM
s-10 carrier bearing, how do you check them catscan4free Transmission - Rearend 2 01-24-2004 05:45 PM
