Torrington Bearing between Direct and forward drum? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2008, 06:31 PM
6426yy's Avatar
Trying to Air check my clutch packs. The first time around I broke a sealing ring and had to order a new set. So it's been a few days since I've tore it apart. Now my INT clutch and direct clutches engage fine but my forward set won't hold air. I think I left out the bearing between the direct and forward drums. Does this sound right? All the seals look good. It pumped up twice then started leaking again. I figured this was because the vasaline only held up so long.
Any thoughts, thanks
Old 05-05-2008, 08:26 AM
No. You should not have 'spare' parts of any kind and may very well have other issues.
Old 05-05-2008, 03:28 PM
6426yy's Avatar
Yeah I left out the bearing, It's all good now. thanks
90/91 - 93 AOD Forward Clutch Drum ? macx Transmission - Rearend 0 05-18-2005 09:03 PM
