toruqeflight 727 problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 08:25 PM
i have a 85 dodge ramcharger with the 727 tranny. it has no reverse but when shifted the reverse the engine will idle down like it is wanting to go into reverse but will not move. all the forward gears are good though and working just fine. any ideas????
Old 01-24-2011, 08:43 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Sounds like a rear band problem.
Broke band, worn out, way out adjustment, servo sideways in bore, servo broken.
Dropping the pan will aid in diagnose of the problem.
MSD problems davesvt Electrical 3 10-04-2009 12:27 PM
tpi s10 having some problems blwn98gtp3800 Engine 15 09-05-2008 07:43 AM
Lifter Problems/Head Problems lewisdanw Engine 4 04-16-2006 01:47 PM
New cam problems? NOlowrider Engine 0 02-21-2005 07:32 PM
327 problems 1963vette Engine 7 09-08-2003 08:37 PM
