Torx socket size - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2010, 10:29 PM
truckboy61's Avatar
Torx socket size
I'm in the process of changing my brake pads and need a torx socket to remove caliper, problem is never used torx nor do I have any . I can place a 8mm hex wrench in center of bolt head what size would this be in torx sockets?
Old 05-02-2010, 08:20 AM
Wiki Edits: 31
no you need the Torx... IIRC GM uses anywhere from a T-30 to a T-55 depending on vehicle type and size
Old 05-02-2010, 09:59 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Try a T55- the 8mm doesn't quite fit inside of a T50, IIRC.
Old 05-02-2010, 10:35 AM
truckboy61's Avatar
Thank you will see if I can find a t 55
holley jet size markzepp820 Engine 2 03-31-2007 11:23 PM
Garage size options 66GMC Garage - Tools 62 02-28-2007 10:32 PM
Is There An Exhaust Size Rule Of thumb To HP Rating? 64nova Engine 10 11-07-2006 12:59 AM
87 Lincoln Rear Caliper Banjo Bolt Size? sonicweb Suspension - Brakes - Steering 2 08-30-2006 02:00 PM
S-10 tail pipe size catscan4free Engine 3 02-23-2004 03:34 PM
