Tot rod - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2013, 03:36 PM
Tot rod
Hi all I'm new to this forum. I've just brought my boy a 34 ford tot rod. Does anyone know where I would be able to get hold of plans to build a chassis for it????
Thanks craid
Old 02-05-2013, 04:58 PM
delawarebill's Avatar
frame
i recall that "spirit ind" in mountain home AR. if i recall correctly they offer a mini Tbucket. try them and see if the frame will fit your needs.. maybe they make them too and u can get plans..
spirit sells t bucket's (full size that is)
Old 02-05-2013, 07:41 PM
life is a temporary assignment
Just need to make a go-kart type frame under it..
I have a pedal car body I made that look's like a vette and has a 5hp briggs in it.. It's the same sizes as a reg Pedal car,, With a 6'-240 lb guy(me) on It, it will run on the back wheels as long as you can hold on at about 30 + mph,, My motor is down right now.. Should be back running soon..
Old 02-07-2013, 11:10 AM
I've just brought it for my 13 month old son (nothing wrong with starting them young) so I've got a while to get it built and painted just not 100% sure where to start.
Finally Clear! Rat Rod and Ratty Rod!!!! Not A T 25 Hotrodders' Lounge 16 08-31-2007 06:37 PM
tot rod mike c Hotrodders' Lounge 2 05-02-2007 12:40 PM
Need help finding a rod bearing for the youngsters Hot rod 62CHEVYC10 Engine 2 04-10-2007 07:54 PM
using piston made for 6 inch rod on a 5.7 rod 67Heaven Engine 3 01-01-2007 01:44 PM
powerband sbc 350..6" rod vrs 5.7 rod Dave Y. Engine 1 11-08-2002 08:01 AM
