Total 700 R4 rebuild required? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2013, 05:47 PM
I just had my local mechanic shop install a trans I had rebuilt in my 84 C 10 and discovered it started to short shift 1st, 2nd and 3rd. The installer readjusted TV cable and still had same problem. I also had other problems with the engine bogging down under load when I would try to engage passing gear. After several 1 mile runs trying to diagnose problems I noticed the trans dipstick was smoking. The fluid was extremely hot. After cooling, I did exchange 4 quarts and next day drove a few miles, came home and noticed fluid hot again. I finally discovered that the individual that changed out the trans, hook the lines backwards at the trans. Therefore, I had no circulation/cooling. He did not flush the system either as the same thing happened to the previous transmission. After installing a large hayden trans cooler, I started driving the truck and it would start out in 2nd and not change gears. When i would give the gas it would just rev. What am i looking at for repair. Does entire trans have to be rebuilt or just cleaned? Can the valve body be flushed or will I have to have it replaced. The shop that did the exchange is going to make it good but i want to make sure I end up with a good trans that i paid for. Thanks!
Old 04-22-2013, 09:17 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
I do believe (know) the trans is fried, & in need of another rebuild.
Rich
Old 04-22-2013, 09:44 PM
If using an aftermarket radiator with a transmission cooler in it, is it critical what transmission line goes to where? I thought I read the you wanted the oil to flow to the top of the radiator and return out the bottom? Which would mean bottom to top (trans to radi), bottom to top (radi to trans).
Is this correct?
Old 04-23-2013, 06:55 AM
Last journal entry: Still running strong
On the trans, top port pumps fluid to the cooler, bottom port receives the cooled fluid.
Old 04-23-2013, 09:50 AM
[quote=dogwater;1669516]
Wrong!
http://www.transmissioncenter.org/Au...Goes_Where.htm
4L60E rebuild--updates required? abbazabba Transmission - Rearend 7 07-26-2012 10:45 PM
1954 Chevy Truck - Total Rebuild Guide??? chriswuzhere Hotrodding Basics 2 12-17-2010 03:42 PM
66 stang total rebuild floyd456 Introduce Yourself 1 08-18-2007 05:47 PM
Total teardown and rebuild of the Dodge Big Blocks Rock General Rodding Tech 1 04-15-2005 10:37 AM
need help on my first total rebuild dusterbd Body - Exterior 9 06-22-2003 01:34 AM
