Total electric advise - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2003, 02:16 AM
impala master's Avatar
I have a 63 impala that has virtually no wires running from the headlights to the dah then to the tail lights its only wired from ignition to starter,what i was thinking was would it be better to try to go back and replace all of the wires somewhat original or would it be worth the time to take a monty carlo 80's model and use the fuse box and go ahead and add tilt steering and just run all my electric from the monty carlo harness?????
Old 09-13-2003, 05:00 AM
awsum34's Avatar
You could, But i would go with a aftermarket harness. That way everything is new. and won't have any splices, nicks or cuts in the wiring.
Old 09-14-2003, 10:19 PM
E.T. divided by $ spent= Speed
If the monte harness isn't butchard I'd use it.But befor you do anythng I would untape it and bundle each circuits wires together with tiewraps.I had to do a ton of work on my half wired hotrod this week and with it all taped and not knowing auto electric and color codes it was a disaster,which ended up in my bundleing each circuit for future referance.
Also there will be a ton of wires that you prolly won't use that you'll prolly want to bundle off to the side or just get dareing and cut off.
Old 09-14-2003, 11:24 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Painless, Ron Francis, EZ Wire.
Old 09-15-2003, 03:34 AM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
For $165, I would buy an EZ-Wire kit and rest assured.
Alan
54 Chevy Pickup
