Total Timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2007, 08:35 PM
Novabrian's Avatar
Total Timing
Ok I have a crate motor from Year One. It says the total Timing is 38 degrees. How do I find out what to set the initial timing at?
Engine Specifications:
·Horsepower: 400+
·Torque: 400+ ft/lbs
·Compression ratio: 9.5:1
·Dyno-tested: Yes, includes balancer and 14" flexplate
·Dyno sheet: Included with engine's output
·Vacuum produced: 12hg @ 800RPM
·Recommended fuel: 92 octane
·Max recommended RPM- 6000
·Block: Seasoned 4-bolt iron
·Crankshaft: Nodular iron
·Pistons: Hypereutectic
·Connecting rods: Powdered metal
·Camshaft- Hydraulic roller
·Valve lift:.520"
·Duration @ .050" (int/exh): 218deg/228deg
·Rocker arms: 1.6:1 ratio
·Cylinder heads: Ported Vortec
·Valves: Stainless steel 2.02 int/1.60 exh
·Valve springs: Heavy duty
·Bore x Stroke: 4.030" x 3.48"
·Intake manifold: Dual-plane aluminum
·Oil pan, timing cover, valve covers included
·Engine fasteners: High tensile strength
·Warranty: 12 month/12,000 miles
Old 05-04-2007, 08:50 PM
With the vacume advance line disconnected you can connect a timing light, then rev the engine up untill there is not more timing advance and turn the distributor for 38 degrees total, then idle it back down and see where your inital timing ended up. Most engines with a mild street cam like yours will like about 12 degrees initial but it may take some playing around to figure out the best setting. If the inital setting messes up your total advance then you'll need to modify the mechanical advance limit. The amount of mechanical advance can be figured out with the distributor out of the car using a simple protractor just remember the distributor turns half the speed of your crank so double the distributor degrees to get the actual crankshaft numbers.
Timing Marks ??? Zeder Engine 10 06-18-2013 04:19 AM
running no vacuum advance oregon chevelle Engine 28 02-07-2007 07:17 PM
No ported vaccum port in my Q-jet, help Augusto Engine 11 12-27-2006 05:04 PM
Help BG Tech Can;t Breath Can't Tune Ratchet Engine 34 09-29-2005 05:25 PM
Trust the timing light or the timing pointer? lluciano77 Engine 6 03-06-2004 01:35 AM
