Touch up paint??
I've got some bolt/screw heads and a couple of small spots to touch up. I've got the paint, a quart left. Now I've tried putting some on when I'm spraying other parts but it just seems to thin and takes way to many coats. If I mix up a little batch with the right amount of hardener but just a small amount of reducer will this work better??
Thanks |
touch up paint.....
hi,i dont know what the mix is for your paint,but its either 2 to 1 or 4 to 1 (paint to hardner) (catylst) use a paper cup,NO WAX CUPS..mark the cup with a magic marker,in increments, put paint to 2 nd line and cat to 3 rd line, that would be 2 to 1 mix (make even lines) or paint to 4 th line, cat to 5 th line.(that would be 4 to 1 mix.for really small amounts,make the lines closer together.(i know this is hard to explain) dont use reducer or thinner.use small artists brush. hope this helps.
Use a 4oz shot glass, the kind sold at liquor stores.
They have lots of different graduations for measuring. If you're going to touch up with a brush, don't use any reducer, just paint with activator. I usually spray them by using a wood block with holes or dowel rods for hinges. Putting epoxy primer on first relly helps them to scratch less. http://i51.photobucket.com/albums/f3.../DSC03805a.jpg These 1oz measuring cups are nice too. http://cgi.ebay.com/Disposable-Medic...QQcmdZViewItem |
| The paint did not harden | powerrodsmike | Body - Exterior | 27 | 03-05-2009 05:34 PM |
| Paint Question #157 | rj57 | Body - Exterior | 5 | 10-31-2007 02:20 PM |
| wax and grease remover | adrock430 | Body - Exterior | 14 | 07-30-2006 12:18 PM |
| Painting roof tips needed..... | Bluepen | Body - Exterior | 7 | 09-10-2005 09:26 PM |
