Touch-up spray bottles? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2005, 11:25 AM
cruzinTLT's Avatar
Lovin' The Cruzin'
I am getting my 1990 dakota ready for sale, and have to do some minor rust repair before I put it on the market. I have a pint or so of paint left over from the paint job I had done on it a couple years ago. I don't have access to an air compressor/paint gun set-up, but I have seen those glass bottle sprayers with the propellant on the top (can is part of the lid). Will that work? Where can I find one? I am not looking for perfection; the areas are small and won't be hard to paint.
I look forward to your comments---thanks!
Old 08-03-2005, 06:04 PM
pumpkin35's Avatar
paint cans
I know home depot carries the setup you are talking about. Check out harbor freight, they have a refillable can that you can just about pressurize with a bike pump. Bought one not too long ago, works ok for laying polyurethane on wood, but you have to thin the daylights out of the stuff.
Old 08-03-2005, 06:20 PM
They are called preval sprayers. You can find them if you look around, or the body supply shop near you may even carry them. They will spray, but leave a little bit of a textured, orange peel finish. But for a small touchup or something should work, and the nice thing is you could spray some activated paint through it you won't be able to get in a spraycan. I believe they go around 5-6 bucks, but I haven't bought one for quite awhile.
Old 08-04-2005, 08:22 AM
Some automotive paint stores have the capability of loading paint in an aresol, call around and if so bring them your paint. You'll need to add reducer ans also apply a clear over it assuming it's a basecoat/clearcoat. Bob
Old 08-04-2005, 11:34 AM
cruzinTLT's Avatar
Lovin' The Cruzin'
touch-up spray bottles
Thanks guys! I just talked to a paint & body supply shop, and the guy said that a preval sprayer doesn't have enough pressure for spraying metallic paints. I did find a website where I can buy the bc/cc paint in aerosol cans made for touch-up for around $15 a can. I found the paint code for my truck, so I think that will work fine since the areas I am fixing are small (around wheel wells) and I can feather it into the old paint. I'll let you know how it works out!
Spray and re-spray...(long one) VWFan Body - Exterior 9 03-17-2011 11:17 PM
Anyone use this complete spray system to paint a vehicle... 357ford Body - Exterior 24 11-01-2010 09:33 AM
Temp. Spray Booth didn't work very well fordSR Body - Exterior 10 10-07-2004 05:43 AM
I'm good with a spray can.... what am i doing wrong! harrington Body - Exterior 21 04-25-2004 02:28 PM
Need a Good Spray Gun HVLP 63novawagon Body - Exterior 4 04-05-2004 11:23 PM
