Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Touchy front brakes...
Old 02-19-2003, 03:50 PM
HalfOunce HalfOunce is offline
it could be many things first i would check would be make sure the rear brakes are set up high enough assuming this has drum in the rear.
If u r like a lot of peeps that never use the brakes while backing up or never use your emergancy brake the rear will never adjust.
Thus leaving u with nothing more than front brakes.
