Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - toughest paint
Thread: toughest paint
  #24 (permalink)
Old 12-24-2005, 04:29 PM
Timer Timer is offline
HISTORY OF E-COAT
1963
PPG filled first electrocoat tank with anodic electrocoat for automobile bodies
1969
PPG issued patents for the ultrafiltration process
1971
PPG filled the world's first cathodic electrocoat tank and designed/installed the first anolyte system to minimize waste
1972
PPG successfully operated the first color controllable electrocoat system
1976
PPG commercially electrocoated automotive bodies with a cathodic process
1979
PPG commercialized the first one-coat cathodic acrylic electrocoat
1980
PPG filled the first low-cure high gloss, exterior-durable cathodic acrylic electrocoat
1981
PPG introduced UNI-PRIME® cathodic epoxy electrocoat, the first high film build electrocoat
PPG commercialized the first color controllable, one-coat epoxy finish
1985
PPG commercialized 4th Generation cathodic epoxy with reduced film shrinkage
1989
PPG introduced the first "ultra-white, non-yellowing cathodic epoxy for appliances
1990
PPG introduced ELECTRO-IMAGE® electrodepositable photoresist
PPG commercialized 5th Generation cathodic epoxy with improved operating efficiency
1991
PPG developed the first thermosetting electrocoat capable of curing to 180 °F (82 °C)
PPG commercialized the first "two-coat electrocoat process"
1993
Low solvent and solvent free anodic acrylic was developed
1994
PPG introduced 6th Generation ENVIROPRIME® lead-free cathodic epoxy
1995
PPG commercialized high performance, low solvent, anodic acrylic
PPG high gloss, low cure, reduced VOC (less than 1.5) cathodic acrylic
1996
PPG introduces HAPs-free, low cure, cathodic acrylic electrocoat
Cathodic acrylic clear-coat technology was commercialized and is used on a variety of substrates: gold, silver, brass, nickel, copper, zinc, aluminum, and steel
1998
PPG introduced one component 7th Generation cationic epoxy electrocoat
2000
Commercialized FrameCoat – high edge coverage, zero rust spot cathodic epoxy electrocoat developed especially for frames.
2000
POWERCRON 8000, 8th generation single-component, high performance, HAPs-free, low VOC (<0.1), low-cure, and lead-free cathodic epoxy commercialized.
2000
Commercialized POWERCRON 8000HE – high edge coverage version of POWERCRON 8000.
2001
Commercialized POWERCRON 940 Platform – cationic acrylic electrocoat that can be optimized for any combination of UV durability and corrosion resistance properties.
2001
Commercialized POWERSEAL® XL – cationic epoxy electrocoat optimized to meet the needs of the Fastener Marketplace.
2002
Commercialized POWERxTM – PPG’s extensive, but easy to use program to test, treat and prevent bacteria and biofilm in electrocoat systems.
http://www.ppg.com/car_indcoat/electro1.htm
THE BEST PAINT SYSTEM ON THE PLANET = BAR NONE.!!!
