tow truck engine build - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2013, 09:26 PM
I hope iIve done enough research on a good tow truck engine. A late model stock bbc 454 with roller cam and one piece rear seal. Run it with a performer intake with one inch open phenolic spacer and a 3310-2 vacuum secondary 750 cfm Holley carburetor. stock compression stock roller cam. a HEI distribiter with a 65000 volt coil. 87 octaine stock 7.5:1 compression. headman 1 3/4" headers, stock 8.8 plug wires. Great truck engine 275 hp at 4200 rpm and gobs of torque 400 to 425 ft lbs from 1600 to 2800 rpm. Bascally stock late modle engine with all the fuel injection removed. Tell me what you think or let me know a good tow truck engine combo. Thanks
Old 09-30-2013, 09:36 PM
vinniekq2's Avatar
thats more than adequate for most trucks.You would have to need more power to justify spending more money on the engine
Old 10-01-2013, 10:56 AM
I do want to keep compression low so I can run the cheap 87 octane.Plus no piston pinging or detonation.
Old 10-01-2013, 10:59 AM
vinniekq2's Avatar
and you think 8.75-9:1 is too high?
Old 10-01-2013, 11:26 AM
No I think that compression is good
re tow truck torque m/w Hotrodders' Lounge 7 01-08-2013 09:39 PM
tow truck torque m/w Engine 23 01-07-2012 04:59 PM
Want a challenge? Cheap Tow truck...... Rob Keller Hotrodders' Lounge 4 02-25-2009 02:03 PM
tow truck takes a hike bullheimer Hotrodders' Lounge 2 01-28-2006 10:24 AM
1940 tow truck-should i keep it or what? bullheimer General Rodding Tech 32 11-08-2005 12:27 AM
