towbar - towing problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2009, 06:35 PM
406 bug's Avatar
9.82 @ 139mph
Built this great towbar so I could get my project car to the paint shop.
Guess I don't quite know much about towing because the first corner I turned the front wheels started shimming and would not stop until I pulled over and stopped. The project car is light about 2200lb. and has rack and pinion steering coil over strut - caster 8deg. camber 0 and tow in 1/16. I have not towed anything before and need someone to school me. Thanks in advance for any help.
Old 02-26-2009, 07:15 PM
poncho62's Avatar
Wiki Edits: 5
You just dont have enough weight over the front end for it to steer on its own........I found this same problem flat towing a car without an engine. What I would do is just tie the steering wheel straight and drag it around the corners. Being light in the front isn't going to damage anything.
Old 02-26-2009, 08:10 PM
406 bug's Avatar
9.82 @ 139mph
The Motor and trans is in the vehicle - and the weight bias is probably on the front.
Torque converter problem??? blacklabzeke Transmission - Rearend 2 12-31-2008 03:55 PM
overcharging problem on 1972 mustang DaSouthWon Electrical 6 08-27-2008 08:17 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
