Use a th350 or th400. The OD is useless for towing. You cannot tow in OD. The trans will burnout of you tow in OD. You will not save gas.
You will not save money. The good old th350 and th400 are much more reliable, especially for towing. |
I'm not interested in the 700R4 for the overdrive while towing. I want the 4.10s to help tow with, but need the overdrive to get those RPM's down when not towing. That is where the concern is. The 3.06 first gear with the 4.10s would sure be nice too.
The truck has a TH400 (that may need rebuilt) right now but it also has 3.07 gears and a 305 engine. It's all getting changed around, since I need to be able to haul a trailer should my 96 3/4 ton ever break down (like it is right now). A broken down truck costs me money, and not just because i have to buy parts, but because the truck tows my trailer which makes me money. Because of this, i need a backup. |
Do a search on this forum and any other about the th700r4 and durability even after all the expensive upgrades. You are barking up the wrong tree if you need dependability.
if your truck has a fairly tall tire the rpm with 4.10's and a th400 will not be excessive. The 454 is a mistake. A high torque efficient 350 L31 vortec motor or a LS series motor (5.3L or 5.7L or 6L) is much better. So is the modern OD trans (designed based on a th400) used behind these truck motors. The th700r4 is a looser. |
Keep the t-400 trans and
Buy a Gear Vendors over drive unit. Very tough and durable 22% over with the GV unit
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I will not use another small block. Small blocks and me dont get along. I LOVED my last 454, the only reason I dont still have it is because it got water inside it during the 2 year storage period that it was out of the truck it came from.
As for the gear vendor unit, if i could find one for a good price I would go with that. Otherwise I might as well go for a 4L80E setup, It would be the same price or cheaper. |
| Transfer case - NP 203 - 205 | jrm123180 | Transmission - Rearend | 2 | 03-24-2006 07:36 AM |
| I need help with ID of a 12 bolt rear end Please ! | rr67gto@aol.com | Transmission - Rearend | 9 | 03-19-2006 03:36 AM |
| 10 bolt vs. 12 bolt. | Iwanttolearn | Transmission - Rearend | 4 | 02-05-2005 10:32 PM |
| How to identify Oldsmobile 12 bolt? | elukas | Transmission - Rearend | 8 | 12-13-2003 10:59 AM |
| just swapped to a 12 bolt and the yolk is wrong! | Destructo | Transmission - Rearend | 6 | 10-14-2003 08:54 PM |
