towing capacity?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2009, 10:13 AM
inquiring_mind2's Avatar
a shade tree mechanic
towing capacity??
I have no clue if I have this thread in the right place. But I will try. Could a 04 or 05 Mitsubishi endeavor pull 4000 lbs??? I am wanting to tow something but don't know it it has the towing capacity to do so. It has the 3.8 l v 6 in it. Any help would be greatly appreciated
Old 07-18-2009, 10:37 AM
DoubleVision's Avatar
Info I get says it`s highest is 3500 for a `07. If it has a automatic it would have to be towed in drive and it would have to have a transmission cooler to keep from cooking it.
Old 07-18-2009, 02:50 PM
techinspector1's Avatar
Wiki Edits: 326
I found myself between a rock and a hard place a couple of years ago, having to use a 2005 Toyota Corolla to tow a 1700 lb trailer from Arizona to Wisconsin. The specs said 1500 lb tow capacity, so being in a hurry, I took the car to U-Haul and had a hitch and the largest trans cooler that would fit on the car installed.
On the trip, I shifted out of overdrive and down a gear on hills to baby the transmission. Took a little longer to get there, but the trans is still intact and operating well to this day. (car belongs to a friend who lives in Wisconsin).
towing concerns with 3-link bagged suspension bet on black Suspension - Brakes - Steering 1 10-17-2007 09:10 PM
Towing capacity 1972 Chev Cheyenne V8 dads 40 General Rodding Tech 2 04-26-2007 01:09 PM
Rebuilding a 700R4 in 4x4 for towing... indy_85stariones Transmission - Rearend 4 02-02-2007 01:26 PM
Empty trailer towing in O/D?? schnitz Transmission - Rearend 18 06-27-2005 12:52 PM
Street Rod Alternator Capacity? JohnTN Electrical 2 11-27-2004 04:41 PM
