Toyota 4 runner injector leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2012, 07:42 PM
My cousin has a toyota 4 runner that is driving him nuts. . . . He has one injector leaking, he fixes that, then another leaks. . . . any suggestions on how to install them so none of them leak??? it is a v6. . . . . THX
Old 05-11-2012, 07:53 PM
LATECH's Avatar
If they leaking a the pintle into the intake, just put in all new injectors.
If the rubber O rings are leaking , you should change all 12 of them when you take it apart.It only makes sense that they continue leaking.
Like a rusty chain, you pull a car with. The chain breaks, you weld it up, try again , and the next weak link breaks. Solution: replace the entire chain.
Just like injector seals, replace the whole set.
Fact is stranger than Fiction
toyota 4 runner doesn't run gfestep Engine 3 04-19-2012 05:50 PM
Will she be a runner. Studebaker Engine 4 11-20-2008 08:01 AM
1995 Toyota 4-runner sun roof jojob4u Interior 0 07-14-2008 10:45 PM
Hello from 70 Runner 70 runner Introduce Yourself 3 11-16-2005 09:52 PM
ford 7.3L diesel injector pump output line leak snowman Engine 3 09-18-2002 10:00 PM
