toyota celica gt timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2010, 02:30 PM
Where do I start?
Old 07-23-2010, 07:20 PM
LATECH's Avatar
clean and mark the timing marks so you can see them plainly. Use white paint or even better white out from an office supply you have laying around.There is a diagnostic connector under the hood and read the label.the diagrahm usually is inside the cap over the connector. It shows a picture of the diagnostic connector and which 2 conections to jump for setting the timing to base timing for proper adjustment of the distributor
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
Timing Timing Timing bigcountry1009 Hotrodding Basics 6 01-20-2009 05:47 PM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
ignition timing bad502 Engine 21 02-20-2006 06:57 PM
