Toyota Rearend. To Weld, Fozzy,or Spool? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2009, 11:26 AM
I have a 1989 Toyota. I just rebuilt the bottom half of the motor. I just put a 3inch body, a 4 inch suspension. I am running 35s on it at the moment. I want to lock my rear end. I was thinking of having a shop weld it, then I got to reading does anyone have any ideas about the Fozzy? I might go with a spool but I will be driving on the road half the time. But I do a lot of trail riding so I want the extra traction. I do not have a lot of cash flow at this time. I dumped most my money in the Engine, lift , tires. Thanks
Old 03-29-2009, 09:57 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Welding the gears or a spool on the street is not a wise choice.
What is a Fozzy?
Old 03-29-2009, 10:10 PM
LEE EYES's Avatar
Last journal entry: TBI experiment.
wow. i'm really glad im not the only one wonderring what a fozzi is. lol. electronic locker would do a nice job for you. 4runners in the 90's had them. not sure on other applications.
Old 03-30-2009, 01:28 AM
if it is a 50/50 trail truck street truck I would weld It I have trail trucks and I welded all of them up I even have a street truck that I welded the rear end up in its cheap but all that money you spent on those tires it will wear those out fast on the asphalt
Old 03-30-2009, 01:39 AM
RippinRon's Avatar
What is a Fozzy?
Maybe he means fozzy traction!!?? Its posi with a Japanese accent!
Old 03-30-2009, 02:34 PM
prostreet6t9's Avatar
Differential/Driveline
I wonder if he meant Aussie locker?
Old 04-01-2009, 08:31 AM
A Fozzy
a FOZZY is were you weld up the spider gears every two teeth, you fill the weld of two. you go all the way around like that. It alows for a little play. I have heard some good things like your truck will handle turns on the road a little better, but also the weld wears out of the gears..Just wondering if someone has done it before and had any input.
Old 04-01-2009, 12:20 PM
I dont think I would do that it kind of gives the spider gears a little momentum to break the gears or whole carrier and you are barely gonna get any play going around a corner before it posi's up and skids the tire around the corner anyway here are some pics of some good ways to do it
http://www.pirate4x4.com/forum/showthread.php?t=663602
Old 04-01-2009, 01:31 PM
LEE EYES's Avatar
last time i welded a rear end it ended up shearing an axle. saw it fly out right befor i hit the ground. you have a full float though so have a ball....
Old 04-01-2009, 04:14 PM
Weld
Thanks for the advice. I think im going to weld it for now. When I get the money Im going to with the dirty thirthy ( 30 Spline Chromalloy axels). Dont want to spend the money on a locker when im going to switch it out later.
Old 04-01-2009, 05:21 PM
That sounds like a recipe for a broken rear end. A welded rear is not as bad as people make it out to be, especially in an under-powered and over-tired toyota. If you up your tire pressure you'll hardly know it is there. The other benefit is that it is consistent, some of the auto-locker do strange things sometimes. But, if you're paying someone to weld it, you might be able to get a lunchbox locker for not much more.
Old 04-01-2009, 06:57 PM
LEE EYES's Avatar
i almost forgot that taller tires have less speed difference around corners....
Old 04-01-2009, 07:05 PM
Old 04-01-2009, 07:11 PM
LEE EYES's Avatar
sarcasm. tire size doesn't matter... unless tires are different sizes from one side to the other. and power makes a difference, but in this case he needs to worry about axles shearing and carier cracking... lot of stress created in a turn, and if the tires dont lose traction, something else will give.
Old 04-01-2009, 07:19 PM
Ok.
What I meant about the big tires was that usually toyotas with them on are pretty sluggish. You are right that it puts more strain on parts but I have had pretty good success with a welded rear, several rubicon trips without breaking it. Our "community spare" 3rd member is welded as well. I did switch to a detroit after awhile though for tire wear issues, welded is really rough on them. I honestly think that the welded rear had better on road manners than my detroit though, mostly because it is ALWAYS predictable.
Josh
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
Question on Mig Welding - HOW to modas Body - Exterior 43 12-31-2005 09:48 PM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
