Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - toyota truck rear axle
Old 12-02-2012, 02:54 PM
JeffB's Avatar
JeffB JeffB is online now
1988 to 1993 have the improved lubrication and valve body and are non computer, one from a Mustang would be a good donor they seem to show up on craigslist for decent prices since the T-5 swaps have gotten popular, you will need this: Ford SFI Flexplate 164 Tooth 28 oz - 289 302 351 C4 AO - KMJ Performance to have the correct flexplate since your 302 is 28 oz balance the later AOD's were 50oz.Lokar makes a T.V. cable that is an EZ install not much else needed.If you keep the disc brake rear you now have with the AOD it will come off the line quick and cruise at 70 about 2200 RPM.About perfect for MPG cruising.
